Re: 656 Hydraulics
Posted by CEB on January 04, 2006 at 14:29:43 from (199.150.177.135):
In Reply to: 656 Hydraulics posted by jkspratt on January 04, 2006 at 07:02:29:
Also, you will see pumps of 12 GPM and 17 GPM listed for this tractor. They are basically the same pump and either can be used on your tractor. They get the higher GPM by shimming the gears inside the pump to slightly closer tolerance. The 17 GPM pump is usually about $30 or $40 more than the 12 GPM pump.
