Re: 1066 wheel hubs
Posted by the tractor vet on January 04, 2006 at 15:00:46 from (4.124.76.79):
In Reply to: 1066 wheel hubs posted by TN1066 on January 04, 2006 at 14:49:33:
The wedge loc is far better then the clamp style as they will take more pony power the clam style will break when you get much over a 100 hp and put them under a strain , have you tryed installing a new wedge as this sometimes will solve the loose wheel problem.
