Farmall 300 Points Take 2
Posted by IaGary on January 04, 2006 at 15:06:10 from (207.32.0.46):
Took apart the wobbly distributor today. I believe this has been modified. The housing and tube that the weights and shaft are in has a removable brass bushing that wore. Bushing is about 2" long .625 OD x .485 ID and does not show up in parts fish. So am going to make a new bushing to try to tighten it up. New dist. is over $250 unless someone knows of a cheaper one. Shaft is not wore it measures the same from end to end. My local mechanic has never seen the bushing before either.
