Re: OT electrical question for John T and others
Posted by Hermit on January 05, 2006 at 19:14:23 from (69.21.48.123):
In Reply to: OT electrical question for John T and others posted by Bob M on January 05, 2006 at 09:54:24:
Could it be that the diodes are the source of the field current? If one of the diodes was shorted, the resulting voltage to the field would be a rougher, shallower pulsating DC not allowing full build-up of output voltage. Or if one of the slip-ring brushes was stuck in the holder, broken brush spring, corroded brush end, etc., not allowing current flow. It's a theory anyway.
