Re: another super c electrical question
Posted by KEB on January 05, 2006 at 19:56:41 from (209.108.192.162):
In Reply to: another super c electrical question posted by ny bill on January 05, 2006 at 18:25:51:
OK, if I'm reading this right you say it will charge to 15 volts when the lights are off, but drops to 12 volts when the lights are on. That means one of two things...first, there's a high resistance connection somewhere between the alternator & the point where the power for the lights is taken off, or second, the lights draw more current than the alternator is capable of producing. If its the first case, the high resistance connection could be in the wiring, or it could be in the ground path between the alternator case & the tractor chassis. Another possibility is a bad ground connection on the battery itself, but that should manifest as a cranking problem as well. Measure the output voltage of the alternator at the alternator with the lights on and the engine running. Take two measurements, one between the output terminal and the alternator case, and one between the output terminal and a good ground. If there's more than a few tenths of a volt difference, check the alternator mounts for a good electrical connection to the engine block. If there's no appreciable difference at the alternator, make the same measurements between the positive battery terminal and the alternator case, and between the battery positive terminal and a good ground. If there's a difference here, you have either a bad ground somewhere or a bad connection in the charging circuit between the alternator and the battery. In this case, measure the voltage between the positive battery terminal and the output terminal of the alternator. If there's more than a small voltage drop between the battery & the alternator, you have a bad connection in the charging circuit. If there's not, you have a bad ground somewhere. If the output at the alternator is in fact only 12 volts, check the wiring of the regulator input (assuming its not a one-wire alternator). If the regulator is wired correctly, you probably need a bigger alternator or smaller lights. Good luck, hope this helps. Keith
Home
| Forums
Today's Featured Article -
The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
