Re: another super c electrical question
Posted by Brownie 45 on January 06, 2006 at 04:08:51 from (207.177.82.245):
In Reply to: another super c electrical question posted by ny bill on January 05, 2006 at 18:25:51:
If you have a delco alternator, & it sounds like you do, of the 2 small push on spade lug terminals numbered 1&2, #2 is the terminal that senses battery voltage [should connect to the positive battery terminal or as close as possible]. A #16 or 18 wire is all that is needed. Make sure connections are clean. Lots of folks just use a short heavy wire between the output terminal & #2 terminal. This works, but doesn't sense true battery voltage at the battery especially if there is a high resistance at or near the battery/ starter area. I would check for clean tight connections throughout the whole system.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
