Re: 424 Starter problems! Please help!
Posted by Janicholson on January 07, 2006 at 14:06:42 from (66.173.50.124):
In Reply to: 424 Starter problems! Please help! posted by T. Hazen on January 07, 2006 at 13:46:51:
Diagnosis is the major element in the process. 1} When "nothing" happens is there lots of current flowing? (use a starter current meter ~12-18$ at the auto/tool store, pushes against the battery cable and reads in hundreds of amps.) If the current there is in the several hundreds 400-600, there is a direct short to ground, either in the starter, or the heavy wiring to the starter. Have starter checked. 2} If no serious current, then the starter may be open (no conductivity inside, ergo bad brushes or similar open circuit). Or the solenoid is open (bad) To check this (again if no serious current) check to see if full voltage is on the starter side of the solenoid when the key is turned to start (momentarily) 3} Also if no serious current the start terminal (small with S usually) fron the ignition switch may be tested for voltage withe the key to start (momentarily). If none then the circuit to the key from the starter (usually a smaller #10 wire leading from the battery side of the solenoid to the dash area) through the amp gauge, if it has one, to the key and back to starter may be open. Good luck, JimN
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
