Re: 424 Starter problems! Please help!
Posted by El Toro on January 07, 2006 at 14:44:53 from (205.188.117.73):
In Reply to: Re: 424 Starter problems! Please help! posted by T. Hazen on January 07, 2006 at 14:16:14:
You can bypass your starter button by shorting
across small S terminal on your solenoid to the other small terminal that feeds voltage to your ignition switch with a screwdriver. Make sure the tractor is out out of gear. Hal
