Re: Clutch vibration on Super C
Posted by Ted in NE on January 07, 2006 at 16:52:26 from (63.172.253.38):
In Reply to: Clutch vibration on Super C posted by farmer Jonathan on January 07, 2006 at 16:35:07:
Check the pilot bushing in the end of the crankshaft. When they get loose the clutch disc drags on the inside fo the flywheel & causes a vibration. Also check the bolts in the U joint on the back end of the clutch shaft
