Re: dyno#
Posted by the tractor vet on January 08, 2006 at 12:18:08 from (4.124.80.238):
In Reply to: dyno# posted by swetting red on January 08, 2006 at 09:04:15:
The problem is that when you go up to far without a hair dryer you will not be burning the fuel and that leads to washing the cylinder walls And then the added heat . Mine is set up 15% and i do not want to go any higher . Now if you add a turbo ( hairdryer) and add the cooling jets to the bottom of the pistons put bigger valves in it then the old sayeing is when the go they go but when they GLOW THEY BLOW.
