Re: m belt pully rpm
Posted by captaink on January 09, 2006 at 06:52:01 from (66.115.214.56):
In Reply to: m belt pully rpm posted by Pa Dave on January 06, 2006 at 19:24:38:
As you work on this, keep in mind that if the pulley on the tractor and the sheller are not exactly the same size, the RPM of the tractor pulley won’t tell you what you need to know, the RPM of the sheller.
I had a Minneapolis Moline 1210 sheller that was PTO drive. It seems to me like the driven sprocket was smaller than the driving sprocket, meaning that the main shaft of the sheller ran faster than the 540 PTO speed of the tractor.
You can find out the speed of a spinning shaft with a tachometer or you can measure the circumference of the pulleys and do a percentage and calculate it.
