Re: Reverse battery polarity on Super M
Posted by Janicholson on January 09, 2006 at 08:54:52 from (199.17.6.175):
In Reply to: Re: Reverse battery polarity on Super M posted by Jeff Jackson on January 08, 2006 at 12:51:57:
Because of our lack of history on the unit, I will start here. If the battery in the tractor was installed with negative ground when you bought it, and the electrical system was working, then they repolarized the gen, for neg ground and used a neg ground regulator. At that time they reversed the leads to the amp meter to have it show correctly with the opposite polarity. If you now have it turned around to pos ground, the replacement vr will be wrong polarity and the amp gauge will be backwards as well.
I hope this sheds light, if not let us know in a new post, not this one, Thanks JimN
