Re: 140 Farmall 6 or 12 volt
Posted by El Toro on January 09, 2006 at 16:03:10 from (205.188.117.73):
In Reply to: 140 Farmall 6 or 12 volt posted by Curt Cooke on January 09, 2006 at 05:47:03:
You probably need to have the generator and voltage regular checked at your local auto machine shop that repairs starters, generators and alternators. All those wire connections on the generator and regulator should be cleaned of any rust. Then see if you have any voltage output. You should either buy or make a new wiring harness. I would makeup or buy new 00
battery cables too. Hal
