Re: Ok time to tell me how to replace the main bea
Posted by JakeF on January 09, 2006 at 20:07:22 from (64.146.188.222):
In Reply to: Ok time to tell me how to replace the main bearing posted by Kelly C on January 09, 2006 at 17:51:12:
The easiest way to remove them is with an aluminum pop rivet that has the steel pin pulled out. Just make sure you roll the bearing out the lock tab side. By the time you are done laying under it and having it drip oil in your eyes you will wish you had pulled the engin though. Jake
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
