Re: Ok time to tell me how to replace the main bea
Posted by captaink on January 09, 2006 at 20:10:27 from (64.33.250.37):
In Reply to: Ok time to tell me how to replace the main bearing posted by Kelly C on January 09, 2006 at 17:51:12:
Kelly,
I’m going to throw a couple more things at you to consider.
How long has it been since that block has had the water passages really cleaned out good? That’s what I thought. One thing that I didn’t notice anybody mention (since early today) in the reasons for a burned valve was poor water circulation resulting in hot spots in the head and block.
It will also be a lot easier to do a good job replacing that rear main seal if the block is out.
You will make the final decision, since it is your time and money going into it.
My 2 cents
Today's Featured Article - Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee ... [Read Article]
