Re: 350 utility hydraulic relief valve
Posted by Cub149 on April 08, 2009 at 19:25:50 from (98.17.208.151):
In Reply to: 350 utility hydraulic relief valve posted by DYNA490 on April 08, 2009 at 17:12:28:
1200 psi is correct. I think the relief valve is external to the resevior, sandwiched between the rear hydraulic control valve and the resevior.
