Re: Tuff front pully on SA, wont budge
Posted by Dave BN on January 09, 2006 at 23:02:01 from (205.188.117.73):
In Reply to: Re: Tuff front pully on SA, wont budge posted by scott#2 on January 09, 2006 at 18:04:33:
No real words of wisdom but lots of sympathy. How dissapointing to think you were done and now to have this! I would spray as much LiquidWrench in there as I could and let it soak overnight. Then I would tap on it with a medium ball peen hammer for about 30 minutes getting all the way around the pully hub by turning the engine periodiacally. Then I would heat it some and pull like h*## with the puller. I've seen guys use an impact wrench on their puller though I've never tried that. I would be concerned about putting too much heat on the bearings. Others would be a better judge of if you have damaged them. GOOD LUCK. Dave.
