Re: Tuff front pully on SA, wont budge
Posted by IaGary on January 10, 2006 at 04:37:17 from (216.51.139.212):
In Reply to: Tuff front pully on SA, wont budge posted by scott#2 on January 09, 2006 at 16:45:02:
Was it hot when you were pulling on it hard? If so it may have gaulded together. By gaulding I mean iron was hot enough to start slipping or rolling off of the shaft or inside of pulley. If this did happen you have a problem. Its like the two are welded together and only way to remove is to cut it off. When ever heat is used to loosen stuck parts they should always be cooled before trying to force them apart or gaulding will be a possiblity. Just my thoughts.
