Re: fast hitch carryall
Posted by ny bill on January 10, 2006 at 17:19:32 from (66.24.193.2):
In Reply to: fast hitch carryall posted by J Muehring on January 10, 2006 at 15:06:44:
i built one for the cub loboy. i took one prong from a tool bar and cut the curved piece loose from the prong, then welded them back together with the curve going down this time, under where the platform would be. i welded angle iron to that for the subframe, and used 3/4" plywood for the floor and headboard. its 4' wide, enough for a couple people to ride along in a parade. (okay, so its not a working platform.) but it could be.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
