Re: 460 miss under load
Posted by captaink on January 11, 2006 at 06:01:24 from (66.115.214.56):
In Reply to: 460 miss under load posted by nebcooner on January 11, 2006 at 05:00:32:
Have you done anything to anything (like a carburetor kit) on the tractor just before it started this? If you did, that would be where I’d start looking. If not, as others have said, start with the points. While you are in there, check the rotor and the distributor cap. I’d put in a new condenser while you’re at it. After that it’s plugs and wires.
