Re: Update on Shawn's SC
Posted by Peabody on January 11, 2006 at 18:26:02 from (64.12.117.13):
In Reply to: Re: Update on Shawn's SC posted by Keith-OR on January 11, 2006 at 17:49:15:
Portaband is quick, but the cutoff blade will probably do a cleaner, straighter cut (even if you have to use more than one), with a little grinding and/or filing to clean up the edges. To me, there's not much worse than seeing an axle on a restored machine that has obviously been hacked off. Make it look as close to factory as possible.
