Re: Update on Shawn's SC
Posted by leon on January 12, 2006 at 06:52:54 from (12.219.23.183):
In Reply to: Re: Update on Shawn's SC posted by Keith-OR on January 11, 2006 at 17:56:57:
I found quite a bit of sludge inside the valve
cover of mine, but then it had been running
without a thermostat so not surprising. The
sludge on top is what promped me to open up
the bottom end. There it was clean as a
whistle, but when I put the pan back on it
began leaking like a sieve at the front of the
pan or bottom of the front cover - couldn't tell
which! I sort of suspected that the 'crankshaft
seal oil retainer palte' (6 100 D) which sort of
'floats' in there got disturbed so I pulled it out
and used new seals/gaskets on it wilh a
liberal amount of Permatex. So I'm anxious to
get her running to see if the oil leak has gone
away. I didn't leave the front cover loose 'till
the crank pulley was in the seal because I
used Permatex on that cover too. I don't think
that cover can move around much anyway with
the stud and all the bolts. Hope I got by with it.
We'll see. I used a new crankshaft pulley as
the old one had a crank ear broken off and the
seal groove was pretty bad.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
