Re: thread sealant on diesel fuel lines
Posted by the tractor vet on January 12, 2006 at 08:40:47 from (4.124.72.205):
In Reply to: thread sealant on diesel fuel lines posted by Ronald on January 12, 2006 at 07:33:45:
Well first off i have never ever use any sealant except on the sediment bowl to the tank on a fuel system , if you have a fuel leak then there is a problem and you must address the problem and just what tractor we working on here . Does it have the compression fittings that requier the rubber grometts or is it a flair alot of time the leaks are caused from over tighting and can crack or flatten out the ends . Or are we working with the bandjo where it has two flat copper washers.
