Re: how to post a picture
Posted by Kelly C on January 12, 2006 at 20:58:20 from (63.171.43.140):
In Reply to: Re: how to post a picture posted by handyman33kev on January 12, 2006 at 20:45:16:
Not quite, but you are getting there. It looks like you got the photobucket thing figured out. Then it seems you uploaded that address to the YT server as a image.
That wont work. Just add the address in the Optinal Image URL box on the same page your post is.
Also as a seperate fact. When you are looking at your album at photobucket. The next line under the URL box that says "tag"
If you copy that line. You can just paste it into the body of your post with having to but it into any boxes 1st. Thats how you add more than one image to a post and you can add a image and then type text so it comes under the image.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
