Re: Head Gasket for Internation tractor
Posted by leon on January 13, 2006 at 04:35:17 from (12.219.23.183):
In Reply to: Re: Head Gasket for Internation tractor posted by Pooh Bear on January 12, 2006 at 19:52:59:
The model number or letter is likely shown on
a decal on the side of the tractor's sheet metal
on the front half of the tractor. The serial
number plate's location varies depending
upon model. Look for an aluminum colored
plate about 1 1/2" high and 3" long, held on
with two or four rivets. It may nave been
painted over. Copy down everything that's on
this little plate and take that information to the
Case-IH dealer. If you'd post a picture of the
tractor, somebody can likely tell you exactly
where to look for the serial number plate. You
could also take the old head gasket with you
to the dealership and they could most likely
get the right replacement for you.
