Re: M Farmall Rear End stuck
Posted by Josh H on January 13, 2006 at 08:32:44 from (130.203.208.156):
In Reply to: M Farmall Rear End stuck posted by Jndrgreen on January 13, 2006 at 07:52:38:
I'd check the brakes first. After you are sure thats not the problem, check to see if it is stuck in two gears. If you remove the belt pulley housing you can reach back into the transmission and move the gears by hand. Feel your way around and put them all in neutral and then try again. You can also remove the shifter by punching out the pin that retains it, and looking down into the hole the rails should be lined up together when the transmission is in neutral. I'd be kinda gentle when you are trying to see if you got it unstuck. If this doesn't work, try picking up an I&T shop manual, removing the rear cover, and digging in. Josh
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
