Re: M Farmall Rear End stuck
Posted by old on January 13, 2006 at 08:35:39 from (207.69.139.151):
In Reply to: M Farmall Rear End stuck posted by Jndrgreen on January 13, 2006 at 07:52:38:
If you had said one wheel turned one way and the other turned the other way I would say its tranny, but in your case you have a brake locked up like the other guys says and or bearings bad in that side of the rear end.
