Re: Here I go again-MCV
Posted by SGT K on January 13, 2006 at 09:33:01 from (216.125.213.242):
In Reply to: Re: Here I go again-MCV posted by the tractor vet on January 13, 2006 at 08:58:49:
TV,
I knew I could count on a reply from you!
Filter and oil level are good. Springs in spec??, not sure (I'm one of those guys that really does not know what he is doing, but can't keep himself from trying)
The advice on wetting the gears is excellent, I hadn't thought of that. I will get out the book and see if I can measure or test the springs. I can't picture the sump check plug spring. Maybe I will remeber when I see it, can you give me a little description?
I've never blown anything off of a tractor ;) but I ain't finished either.
Thanks, I'll let you know.
Paul
