Re: Attn: Jeff Jackson: Super M Hydraulics Part 3
Posted by Nat 2 on January 13, 2006 at 11:53:25 from (64.80.108.52):
In Reply to: Re: Attn: Jeff Jackson: Super M Hydraulics Part 3 posted by Jeff Jackson on January 13, 2006 at 09:10:36:
Was the tractor plumbed up like that when you got it? If so, then we can't be exactly sure of what was modified in your belly pump to get it to work the way it's working. It may just be that the belly pump drive was disconnected. All you'd have to do there is plug the holes and reconnect the drive.
Steven's right that a spool valve with float will work best with single-acting cylinders. You can use a basic double-acting valve, but for lowering the cultivators, you'll be forcing oil past the relief valve. It works, but it does lug the tractor down and puts stress on the pump.
