Farmall Tractors Discussion Board
Re: H Carb Float height setting
Posted by The Red on January 04, 2000 at 13:29:41 from (12.75.197.235):
In Reply to: H Carb Float height setting posted by john on January 04, 2000 at 13:26:25:
Note the back of the float. It should be parallel with the carb body when the needle is closed.
Post A Followup
: Re: Re: H Carb Float height setting
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
