Re: M Farmall Rear End stuck
Posted by alfred on January 13, 2006 at 19:38:13 from (216.114.221.82):
In Reply to: Re: M Farmall Rear End stuck posted by Cliff schnitzler on January 13, 2006 at 09:03:33:
Take the shifter out and see if the end is broke off or worn. Might be in 2 gears. A big flat-head screwdriver or a tire iron will help get them back. If that is it have the welder put a 1/4" on and try it. just grind a little off if it is to tight.
