Re: 350 utility hydraulic relief valve
Posted by redrider on April 08, 2009 at 20:18:29 from (66.235.45.149):
In Reply to: 350 utility hydraulic relief valve posted by DYNA490 on April 08, 2009 at 17:12:28:
1200 psi at 10gpm is correct for your 350u. The pressure regulator is the first block up against the reservor. The first hydratouch block attaches to the out side of the pressure regulator. If your tractor has additional hydratouch valves they bolt to the reservor just ahead of pressure regulator. But they are feed through the pressure regulator, the first valve in into the outside of the forward valves. If you have power steering then the flow is out of the pressure regulator and into the out side of both front and rear hydratouch valves. This is to give your power steering priority.
You really need to get your self a parts manuel and a service manuel. These will show you everything you need to know about your tractor.
RR
