Re: Wonder if I can get back out to the shop.
Posted by the tractor vet on January 14, 2006 at 08:21:54 from (4.124.71.64):
In Reply to: Re: Wonder if I can get back out to the shop. posted by Kelly C on January 14, 2006 at 07:02:01:
It would have been a 291 when i was done with it lot more power and just a littel more cost for the boring and i would have decked the block to get it trued up . Did ya get the rods reconditioned ?? and also take a real good look at the cam last three that i did had to have the cam rebuilt as the lobes were stating to flatten out and the lifters were cupped .
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
