Farmall Tractors Discussion Board
Re: 1943 Farmall M
Posted by The Red on January 04, 2000 at 14:12:41 from (12.75.197.235):
In Reply to: 1943 Farmall M posted by Keri Brown on January 04, 2000 at 14:06:52:
Keri for starters, over in the left column under Research, select photo gallery and you will find a Farmall M and Farmall M2 pictures under the Farmall category. From about 1942 through 1953, the Ms looked basically the same with minor changes. Guy Fay may give you a more detailed response.
Post A Followup
: Re: Re: 1943 Farmall M
