Re: Super C logging
Posted by BillWV on January 14, 2006 at 19:05:19 from (129.71.136.35):
In Reply to: Super C logging posted by BrokenFences on January 14, 2006 at 15:41:48:
What would you be powering with the rocker arms?
I've been meaning to build a logging arch for three years now, keeps getting pushed to the back burner. I like the design that uses a choker chain hooked to a sloping beam above; as you pull forward, the chain rides up the beam and lifts the nose of the log a few inches off of the ground. It is just hooked up to the tractor like a trailer.
Good luck,
Bill
