Re: Electrical Box Trouble: follow-up
Posted by Janicholson on April 08, 2009 at 20:33:21 from (66.173.50.28):
In Reply to: Electrical Box Trouble: follow-up posted by Tom in Iowa City on April 08, 2009 at 14:57:48:
You have the wire that supplies the lights hooked to the terminal that the field wire is supposed to go on. The terminal is direct to ground when on all but the L position, and Ill bet the resistor is toast. Please read the previous post I put on the original thread. Good luck. JimN
