Re: 350 utility fast hitch hydraulic questions
Posted by coax on January 15, 2006 at 10:29:32 from (198.178.8.81):
In Reply to: 350 utility fast hitch hydraulic questions posted by robert mangus on January 15, 2006 at 08:41:05:
My 240 U has a valve block to the left(looking Foward)of the mounting block,and the fast hitch is hard piped to the rear under the seat where the dist. block sits.I think the setup is similar for both but don"t quote me.On mine the hard pipe feeds from the top of the valve.....
