Re: Super C distilate tractor
Posted by El Toro on January 15, 2006 at 11:33:48 from (152.163.101.13):
In Reply to: Re: Super C distilate tractor posted by Mopar Motivator on January 15, 2006 at 09:24:07:
My manual shows some of the A's, B's & Super A's
had engines with the 5:1 compression ratio. Some of the H's had 4.5:1 to 6.75:1. You may be able to use a 3.250" sleeve kit in that block. Some of the blocks used in the Super A's had thick sleeves. Is there a place for mounting a water pump? Hal
