Re: 560 throttle lever
Posted by IaGary on January 15, 2006 at 17:35:15 from (216.51.139.212):
In Reply to: 560 throttle lever posted by markloff on January 15, 2006 at 15:50:33:
I'm not real sure but I believe the friction plate is under the dash cover or by the fuel tank somewhere. Just follow the shaft down and I believe you will see it. I hope I'm thinking of the right tractor.
