Re: 350 utility fast hitch hydraulic questions
Posted by TDK on January 15, 2006 at 20:20:07 from (64.12.116.65):
In Reply to: 350 utility fast hitch hydraulic questions posted by robert mangus on January 15, 2006 at 08:41:05:
The block is a check valve #363452R91. It goes underneath the hyd. valve and the hoses to cylinder attach to it. I would try to find one at the same place that you got the valve. One valve is all you need.
