Re: D-239 external tank heater
Posted by jb2 on January 15, 2006 at 20:31:49 from (72.56.121.128):
In Reply to: D-239 external tank heater posted by JT Thornton on January 15, 2006 at 17:25:30:
Hi JT, there should be a pipe plug on the left side of the block above the injection pump. This goes in the bottom of the tank heater. The other plug is in the water jacket on the front right of the engine by the valve cover and the temperature sender. This connection goes in the top of the tank heater. The best place to locate the tank heater is between the starter and the injection pump and the bottom of the tank heater has to be about the same as the bottom of the starter. It is a bit of a chore to route the top hose in behind the fan to the top right water jacket but it is not impossible.
Should start after being plugged in for 30 minutes with tank heater.
Good luck
JB2
