Re: Thanks for starter help and another question a
Posted by old on January 15, 2006 at 20:44:47 from (207.69.139.162):
In Reply to: Thanks for starter help and another question about posted by J Schill on January 15, 2006 at 18:42:42:
Theres only one thing the lead and other additives are good for. Guess what it is??
Well its a way to get you to spend your money and all you get from doing so is less $$ in your back pocket. They don't work don't help and don't do any thing but waste $$. If you want to add some thing to the gas pour in a little tranny fluid once in a while to keep the engine clean and the valve lubed.
