Re: Farmall C top end oil pressure.
Posted by gene bender on January 16, 2006 at 03:19:25 from (66.43.221.211):
In Reply to: Farmall C top end oil pressure. posted by t.r.y. on January 15, 2006 at 17:46:36:
Do you need the correct stud i can send you one. The washer and lock washer have nothing to do with getting oil thru the stud. You can make one easy even using a cap screw just get the holes drilled rite.
