Re: 49 M dist. Hydraulic Levers
Posted by Dave Slater on January 16, 2006 at 10:12:23 from (152.163.101.13):
In Reply to: 49 M dist. Hydraulic Levers posted by fisherman on January 16, 2006 at 07:32:37:
Normally the front lever is locked back and it furnishes pressure for the two way hydraulic valve
you have circled at top.But I see the steel line coming up and teeing to the pressure port.Is it auxilary hook up or is it suppling pressure from PTO pump to the two way valve independant of belley pump?Though I can't see it to good the lower lever looks like a aftermarket disconnect for the belley
pump drive. It disconnects the trans. shaft from
turning the pump in belley reservior.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
