Re: 49 M dist. Hydraulic Levers
Posted by Dave Slater on January 16, 2006 at 16:59:51 from (205.188.116.133):
In Reply to: Re: 49 M dist. Hydraulic Levers posted by fisherman on January 16, 2006 at 14:00:35:
Fisherman, With tractor running in neutral move the bottom lever you circled and let clutch out easy.You should feel splines line up and lock together.If not sure if in gear look under tractor and make sure coupling is turning front shaft.You may have to remove a small metal cover to see.If this is not in gear the hydraulic pump is dead.After the pump is turning pull the middle lever back it should lock there, leave it there. Now move the top circled one either way with tractor running in neutral with clutch out,you should here the engine choke down if pump is working.The lines from this valve will work 2 way hydraulics.This pump only works if tractor is moving or in neutral with clutch out.You may want to make sure there is oil in reservoir.Let us know if you have any luck.One other thing, the middle lever will kick off when pressure gets so high if not manualy locked back.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
