Re: 560 throttle lever
Posted by rtm on January 17, 2006 at 06:28:57 from (152.163.101.13):
In Reply to: 560 throttle lever posted by markloff on January 15, 2006 at 15:50:33:
there is a friction disk under the throttle leaver. to put a new one in use a harmonic ballencer to pull the sterring wheel then take off the handle and the disk is right there. my spring was weak also so i put a split repair warsher above the roll pin and under the spring that helped keep the throdle tight
