Farmall Tractors Discussion Board
Re: H Carb Float height setting
Posted by ltf in nc on January 04, 2000 at 18:30:29 from (206.228.213.151):
In Reply to: H Carb Float height setting posted by john on January 04, 2000 at 13:26:25:
After raising the float did it run "better" or did it run longer? Tom H is correct. Your fuel supply is restricted. Raising the float gives you more stored gas to consume before you then starve the tractor for fuel because the supply is not being replenished as fast as it is burned.
Post A Followup
: Re: Re: H Carb Float height setting
