Farmall Tractors Discussion Board
Re: Re: Promised pics of the f12 hybrid
Posted by Bill on January 04, 2000 at 18:34:47 from (209.182.66.139):
In Reply to: Re: Promised pics of the f12 hybrid posted by Steve T on January 04, 2000 at 17:51:19:
I did not have that shaft out of the machine, so can only surmize what is in there. It may be an input shaft from the jeep, or a home made shaft, or a machine made shaft. In any case, it is mearly a shaft with splines to match the clutch disk, and a nipple to go into the pilot bearing, and a U joint yoke is welded to the other end. It may be the original yoke from the farmall, but the double joint is not there, only one. They appearantly fitted a flange bearing on the inside of the bell housing, to help support the shaft, although I dont know that it is necessary. The clutch linkage is from the jeep, and is more complicated than necessary, and if I ever take out the engine, I will simplify it. It runs suprisingly well, and even sounds good with the straight pipe. The oversize rims from an H that were welded to the cutoff steel gears it up a bit, and the high speed engine makes this f12 fast. I am gonna take it to the fair next fall, and park it next to my friend's regular with the model A ford engine, and see if anybody notices.
Post A Followup
: Re: Re: Re: Promised pics of the f12 hybrid
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
