Re: International 434 Fan Belt Change
Posted by 434 owner on January 17, 2006 at 17:21:51 from (209.91.150.246):
In Reply to: International 434 Fan Belt Change posted by Peter Kuzyk on January 17, 2006 at 15:21:26:
The flange of the pulley closest to the rad is threaded. It will screw off after you loosen a set screw on the flange. When you put the new belt back on be sure that the set screw is tightened down in one of the notches on the fixed pulley.
