Re: I need a mesuring tool.
Posted by Paul in Mich on January 17, 2006 at 18:28:39 from (66.227.138.249):
In Reply to: I need a mesuring tool. posted by Kelly C on January 17, 2006 at 15:28:20:
Kelly, For most rod journals, you can get by with 2 micrometers. One being a 1-2 inch, the other being a 2-3 inch. For farm use, they don"t have to be of Starret quality, but rigid nonetheless. I have bought most of my measuring tools from pawn shops, and have ended up with top quality at bargain basement prices. To measure the Inside dimensions of rod bearings and such, an inexpensive set of telescoping gauges will do the trick, as you can transfer the measurement to your outside mics. If you were measuring closer than + or - .001 you would want high quality measuring tools, but in most applications on the farm, including rod journals, you are measuring + or - .001 or larger. As some have suggested, dial calipers will measure that close, but they are somewhat more cumbersome and prone to be misread when removed from the subject. Plus they are hard to measure roundness.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
